test tones
50ish is where your sub will peak when your box is tuned to 33ish Hz. Theoretically 50hz is where your sub will have the most output i.e. be the loudest.
Setting the input gains has nothing to do with what kind of enclosure the sub is in.
i am talking about the enclosure //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif if the tuning is close to 33hz then the fs of the speaker will peak close 50hz.
What are you talking about?
That is the perfect spot to do that. OEM sub may interfere with the new one and cause cancellation.
371
Do you intend to drive around playing test tones? If your intention is to play music, you should be using music you intend to play to dial in...
But then you could just use the volume knob to rather than pay for earplugs.
761
blowthemup
blowthemup
North Carolina
JimJ
    May 12, 2024
Brendon Jenness
    May 11, 2024
