Tennessee Meet
Just a daily driver too... I have a full Infinity Kappa set-up and it sounds pretty good IMO, but I doubt that it will compete with the stuff that will be there, that and the final install isn't completely finished. (I had to modify my door panels, etc. so it is ugly and has exposed wiring right now..)
imo, the double baffle is way over rated. i have LOTS of internal bracing, and the wooden dowels will prevent upward/downward flex, so i really think it isnt necessary
true...true...if you never really need it, but it never hurts
Any of you TN guys competing in MECA SQL or are you all mainly SPL guys? Just curious.
We should have one,maybe two in sql,and 5-6 in spl.......everyone goin' does know about the mic placement right?,scores will prob be lower than what your used to.
I'll be in the astro w/mojo-jojo on the back,or the minitruck three wheelin on 20's;)
I will be at the MECA Show. What class if I entered would I be in..
2 15"s ported
Orion 1200D
2 Batteries, 1 in trunk. Juss a stock car battery
1/0
What would I be in? Its in a 4 door car
Do you know about the fuse rule in meca?(sub amp must be fused w/in 18" of the amp) figure out what the lowest fuse rating(non-maxi)that you can run,and that will help determin your class.
Meca does fusing x10 +your cone area to determin your press.classs,and then type of install.
OneKrazyKeebler
JUST ME
OneKrazyKeebler
Mt. Juliet, TN
FLOSSINON24S
