Tear the matt or use scissors?
  • Tear it!
    Votes: 10 50.0%
  • scissors FTW
    Votes: 10 50.0%
  • Total voters
    20
I use 3/4 oz sometimes. Not often.
I have huge rolls of 1.5 and 2 oz mat. I tear them all.
I have a box of 4 oz weave that I cut with shears. Scissors won't even budge it.
Tearing frays the edges making it interlock when putting them down. Thats makes it stronger. Joints are weak points and you get joints from straight cuts.
Tearing it up and intermingling the frayed edges of fiberglass from each piece will make for a stronger overall piece.
This would be true except that you will get the same effect by overlapping the cut pieces. If the strands of glass in the mat are short enough for you to tear it apart, then there is no real strength gained. Real strength comes from long strands running randomly all through the piece. Once the strands are interrupted, or if they are short to begin with, it isn't going to matter much. For maximum strength, you should use the largest piece of continuous mat that you can with the longest continuous glass strands.
The strands are not short. They don't really tear as much as it is pulling it apart. The frayed ends are long.
Overlapping cut pieces can create an air pocket. Air = weak spot.
One continuous lay of mat is a good idea, just not always feasable.
There's only an air pocket if you leave one there. If you roll out the mat and make sure that it is fully saturated, there won't be an air pocket.
The mat is glued together with an adhesive that disolves in the polyester resin. It will fray itself as you lay it, whether you cut it into manageable pieces or tear it and end up with strands all over your garage and your hands.
A chop gun cuts it, for what it's worth.
Insomniac119
i can't sleep
Insomniac119
Wichita, KS
blue93corsica
