teamquakecelica tc-9 based sub cutout?
blackbonnie
The Revolution
i need to know what the cutout diameter for the 15" tc-9 based woofers, that teamquakecelica was selling. i remember i seen it somewhere, but i think it was only the cutout for the 12". anyway i cant find it. so if anyone knows the cutout for the 15", that will help me out tremendously. i need it by tomarrow, cuz thats when the building starts. thank you
I did mine 14.09" like it says on the TC Sounds site, fits fine. Might be a smidge big, I can move the sub maybe 1/8 of an inch either direction... but I don't know if it's cause I didn't measure 100% correctly or if it's because I used a jig saw to cut it out.
But yeah that's what it says on http://www.tcsounds.com/tc9.htm and I believe it is the same basket.
I would tend to blame the amp more than tbe sub if all wiring checks out. Skar is known to be on the finicky side when abused (not enough power...
113
280
460
558
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
886
blackbonnie
The Revolution
blackbonnie
Grand Rapids, MI
denim
audiobaun
    May 19, 2024
    May 19, 2024
