Letting go of my last TC2+ 15". Mint condition with some light use. Can be used in sealed or vented enclosures, sounds incredible in either. Will get loud and low with relatively little power. Loves between 500 and 800 watts depending on the enclosure. Hard to find these!
$205 plus shipping.
Specs
Fs: 19.7 Hz
Qms: 4.71
Qes: .399
Qts: .368
Vas: 228 L
Re: 2.97 ohm
Z: 4 ohm
BL: 15.5 Tm
Cms: .25 mm/N
Mms: 260 g
Pe: 500W
1W/1m: 88.5dB
2.83V: 92.5dB
Xmax: 23 mm
Sd: 802 sq cm
$205 plus shipping.
Specs
Fs: 19.7 Hz
Qms: 4.71
Qes: .399
Qts: .368
Vas: 228 L
Re: 2.97 ohm
Z: 4 ohm
BL: 15.5 Tm
Cms: .25 mm/N
Mms: 260 g
Pe: 500W
1W/1m: 88.5dB
2.83V: 92.5dB
Xmax: 23 mm
Sd: 802 sq cm
