Old school db-500. Probably the best low distortion, bang-for-your-buck driver ever made. Musical with great output capability, only needs 400-600w to do it's thing.
Used, with light cosmeticals (swirl type scratches but no dents). Mechanically perfect and it sounds sweet. Exact same performance as the EPIC but has a stamped basket instead of cast. Enjoys sealed or vented enclosures.
• Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
• 135oz top grade magnet structure
• Anti-flux modulation copper shorting ring to lower distortion
• Low carbon steel used for the gap plate and t-yoke
• Pole vent for lower distortion and cooling capabilities
• High excursion 8.5" linear roll poly-cotton spider
• Intergraded woven leads to prevent lead-slap
• 2" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
• Single or dual 3.4Ω (4 ohm nominal) voice coil configuration
• Lightweight brushed and powder coated aluminum cone
• 1" wide long throw, highly durable NBR surround
• High quality thermal flexible epoxies to ensure longevity
Qts0.447 Qes0.481 Qms6.347 Fs24Hz Res3.25Ω Ls2.36 Lp3.51 Rp2.91Ω Dia241mm Vas71.5l mms169g cms244um/M bl13.3Tm Spl86dB
$135 shipped
CONUS only, please.
$135 shipped
CONUS only, please.
