TC Sounds TC2+ 12"
ciaonzo
TheContinental
Old school db-500. Probably the best low distortion, bang-for-your-buck driver ever made. Musical with great output capability, only needs 400-600w to do it's thing.
Used, with light cosmeticals (swirl type scratches but no dents). Mechanically perfect and it sounds sweet. Exact same performance as the EPIC but has a stamped basket instead of cast. Enjoys sealed or vented enclosures.
Double stacked 1" tall ferrite magnets and bored T-yoke for long throw
135oz top grade magnet structure
Anti-flux modulation copper shorting ring to lower distortion
Low carbon steel used for the gap plate and t-yoke
Pole vent for lower distortion and cooling capabilities
High excursion 8.5" linear roll poly-cotton spider
Intergraded woven leads to prevent lead-slap
2" diameter, 4-layer aluminum wire voice coil with an anodized aluminum former
Single or dual 3.4Ω (4 ohm nominal) voice coil configuration
Lightweight brushed and powder coated aluminum cone
1" wide long throw, highly durable NBR surround
High quality thermal flexible epoxies to ensure longevity
Qts0.447 Qes0.481 Qms6.347 Fs24Hz Res3.25Ω Ls2.36 Lp3.51 Rp2.91Ω Dia241mm Vas71.5l mms169g cms244um/M bl13.3Tm Spl86dB
$135 shipped
CONUS only, please.
Would you say it's a good beginner sub then? Cuz this will be my first system.
Hey. You're kind of local to me. What's your goals for the system? You want it more loud (spl) or sound quality (sq) or maybe a combination of both? And what's your budget for everything? This TC is more a SQ sub but they can pretty loud in a good ported box.
I want spl just deep bass my budget is 250. Pm me
I would say this is among the absolute best for a beginner sub but it is also much better than that. The only difference between this and the current version being sold at PE is the basket, the performance is the same. You will be hard pressed to find another driver that will sound this good while doing what it can do.
I'm also selling a 15" version of this driver but this is what the 8" can do. -->
I would say this is among the absolute best for a beginner sub but it is also much better than that. The only difference between this and the current version being sold at PE is the basket, the performance is the same. You will be hard pressed to find another driver that will sound this good while doing what it can doI'm also selling a 15" version of this driver but this is what the 8" can do. -->
. Wow! That 8" it's hard for an 8. How much are you selling the 15"? I want deep bass. I'm on budget though I only is 250 for sub and box..
It's a bit out of range for your budget but the 15" is in this thread. --> http://www.caraudio.com/forums/subwoofer-classifieds/572641-tc-sounds-15-tc1000-epic-rl-i-tc2.html
The 12" will go plenty deep, all of the drivers in this series do. Each one just gets louder as the cone area increases.
Weigh your options and shoot me a PM if you think it will work for you.
ciaonzo
TheContinental
ciaonzo
WI
ciaonzo
