tc baskets
I'm a n00bx
Fixed.
How the hell am I a Fanboi? TC literally told me that not using their baskets and 10" spiders with spacers would yeild an inferior driver as if my stock TC9 has the capeability to be so linear I needed 10" spiders and spacers to keep the coil in alignment. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
Fixed.
That is with the Ti basket only. Not with all baskets. The Ti is a taller basket which needs a longer former and wider spiders. They are not biased, its just fact proven by their testing.
I offered to send my 15" 12 spoke in with it //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
They told me if I didnt use their basket with thoes softparts the sub would be inferior.
Ever use a TC9 with a Ti Basket?
EDIT: I have owned both a TC9 with a Ti and a 12 spoke....The TC9 with the Ti basket i would not go far as saying its an inferior driver. I would say its xmax capabilities are much greater than that of a 12 spoke. I also put 1800rms on mine playing tones. Didnt bottom out or blow up.After about 20mins of tones we took it to a wall socket. Took about a min for it to blow..
And? Xmax has nothing to do with the basket. Espeically since Xmech of the basket is greater than the Xmax of any TC9 dirver I can think of off the top of my head.
If Xmax has nothing to do with the basket, then why is the new XXX 12" in depth? That kind of movement cant be done on a 12 spoke basket.
I was refereing to the TC9. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
there is only so much movement you can get out of a given motor.
You should have stated that then...Those motors are more capable than u think....Until you have used both baskets on the same motor dont think you have any right to say they are biased. Going beyond that, its a product they are trying to sell. They are not saying other drivers are inferior with 8" spiders, they are saying their drivers are inferior with 8" spiders (unless i mis understood what you were saying in a prior post).
how much more do I have to state it?
I wanted a recone kit similar to the IA DP soft parts (SPL oriented) for a stock TC9 on a 15" 12 spoke basket. They told me that they wouldnt do that (though they could) because it would be inferior to their new baskets with the 10" spiders and the yadda yadda yadda.
The TC9 isnt even tall enough to keep the coil in the gap moving forward and not hit the backplate moving backward before the cone/spider hit the basket.
There is no difference major in airflow, if there was I'd think the 12 spoke would win. Basically they wanted me to buy a more expensive basket and soft parts for no reason. That would be Bias.
On top of that, they have openely questioned other comapny's designs. They make good motors but they act like their designs are the only right ones.
02parkave
Banned
02parkave
Oklahoma City, Oklahoma
snoopdan
