T3 TSNS 12" beastly MONSTERS
psychoacoustics
hammer and the evil one
3,468
Buffalo NY
1. Product: T3 audio TSNS
this is a very good woofer not an all out spl monster i built them to play music and they do it with authority
they sound great at low power and blend at 80 hz with my mids like its one speaker
however if you wanted this could break **** like your roof or windshield with enough power they are scarrrrrry
2. Specs: 12" TI basket
silver top trf motors
dual 1.6 ohm dcr coils with a 2.7" ww so they will move really far
2 linear "pink" spiders per woofer with a spacer inbetween ( plenty of spider for up to about 6k a woofer this isnt a stiff black 8")
dual leads per coil
long direct leads
cf dust cap
cf impregnated paper cones
stitched surrounds
tall roll surround
rubber gasket on basket
3. Description/Condition:
used in my daily driver for about 4 months on 1800watts per coil
the one dust cap has a small bit of ca glue showing on the cone i was very sparing when gluing them down and this one loosened up after a month or so
only selling due to not needing such a BEASTLY woofer in a daily driven vechicle they weigh around 70 lbs each and its not necessary as ill never compete or add more power to my truck
these 2 12s are easily capable of pulling a hair trick from very little power in a small box
i have ts parameters from my woofer tester PRO
Re = 1.1185 ohms
Fs = 35.6791 Hz
Zmax = 15.6072 ohms
Qes = 0.3932
Qms = 5.0938
Qts = 0.3651
Le = 0.4872 mH (at 1 kHz)
Diam = 304.8000 mm ( 12.0000 in )
Sd =72965.8753 mm^2(113.0973 in^2)
Vas = 59.9350 L ( 2.1166 ft^3)
BL = 12.6534 N/A
Mms = 251.0940 g
Cms = 79.2458 uM/N
Kms =12618.9629 N/M
Rms = 11.0506 R mechanical
Efficiency = 0.6504 %
Sensitivity= 90.1501 dB @1W/1m
Sensitivity= 98.6946 dB @2.83Vrms/1m
and ill test them again to get broken in specs if you want them
currently they are in a 5 cube box with 2 6" aeros and it slams
i can and will if you want design a box to fit your tastes and spece requirements for free if you buy the woofers
the coils are perfect and they will be a hell of a low end monster
4. Price: :
1100 shipped anywhere in the us for the pair
not willing to split them up just yet unless i got a buyer for both maybe down the road i will
5. Pictures:
mounted in the box
motion shots from the t/s testing.... the woofer tester pro measures them at excursion
pictures and videos of the build and the box they are in here:
and here:
tacoma pictures by psychoacoustics - Photobucket
im an absolute nut about stuff and they are in great shape i did however put a small slit in one surround but its been repaired on the back of the surround and is not visible from the front ( its hard to mound a 70 lb woofer vertically by yourself)
i will package them in a wooden crate and insure them for 500 each and ship by UPS
they will come to you safely i can assure you
yes its a t3 recone on a trf ( the first tsns were of this or a ssxxx variety )
ill fix the links thanks
only lets me post 10 so here are 3 more
bl is 12 thats in the measurement of n/a or newtons per amp
im sure your expecting to see the bl of t/ft or testa per foot where as it would be a BL of 41.98
these are the specs that the Woofertester PRO outputs
woofertester.com
like it says in the first post these are are TSNS woofers.....so the coil is from T3
the ww is 76mm or 3" huge difference in coils these are very large
thats gross
if your serious thiugh im sure there is a shady place in the city somewhere that will buy a kidney or something pretty cheap
psychoacoustics
psychoacoustics
Buffalo NY
psychoacoustics
    Apr 28, 2024
    Apr 28, 2024
