T3 TSNS 12" beastly MONSTERS
psychoacoustics
hammer and the evil one
1. Product: T3 audio TSNS
this is a very good woofer not an all out spl monster i built them to play music and they do it with authority
they sound great at low power and blend at 80 hz with my mids like its one speaker
however if you wanted this could break **** like your roof or windshield with enough power they are scarrrrrry
2. Specs: 12" TI basket
silver top trf motors
dual 1.6 ohm dcr coils with a 2.7" ww so they will move really far
2 linear "pink" spiders per woofer with a spacer inbetween ( plenty of spider for up to about 6k a woofer this isnt a stiff black 8")
dual leads per coil
long direct leads
cf dust cap
cf impregnated paper cones
stitched surrounds
tall roll surround
rubber gasket on basket
3. Description/Condition:
used in my daily driver for about 4 months on 1800watts per coil
the one dust cap has a small bit of ca glue showing on the cone i was very sparing when gluing them down and this one loosened up after a month or so
only selling due to not needing such a BEASTLY woofer in a daily driven vechicle they weigh around 70 lbs each and its not necessary as ill never compete or add more power to my truck
these 2 12s are easily capable of pulling a hair trick from very little power in a small box
i have ts parameters from my woofer tester PRO
Re = 1.1185 ohms
Fs = 35.6791 Hz
Zmax = 15.6072 ohms
Qes = 0.3932
Qms = 5.0938
Qts = 0.3651
Le = 0.4872 mH (at 1 kHz)
Diam = 304.8000 mm ( 12.0000 in )
Sd =72965.8753 mm^2(113.0973 in^2)
Vas = 59.9350 L ( 2.1166 ft^3)
BL = 12.6534 N/A
Mms = 251.0940 g
Cms = 79.2458 uM/N
Kms =12618.9629 N/M
Rms = 11.0506 R mechanical
Efficiency = 0.6504 %
Sensitivity= 90.1501 dB @1W/1m
Sensitivity= 98.6946 dB @2.83Vrms/1m
and ill test them again to get broken in specs if you want them
currently they are in a 5 cube box with 2 6" aeros and it slams
i can and will if you want design a box to fit your tastes and spece requirements for free if you buy the woofers
the coils are perfect and they will be a hell of a low end monster
4. Price: :
1100 shipped anywhere in the us for the pair
not willing to split them up just yet unless i got a buyer for both maybe down the road i will
5. Pictures:
mounted in the box
motion shots from the t/s testing.... the woofer tester pro measures them at excursion
pictures and videos of the build and the box they are in here:
and here:
tacoma pictures by psychoacoustics - Photobucket
im an absolute nut about stuff and they are in great shape i did however put a small slit in one surround but its been repaired on the back of the surround and is not visible from the front ( its hard to mound a 70 lb woofer vertically by yourself)
i will package them in a wooden crate and insure them for 500 each and ship by UPS
they will come to you safely i can assure you
ha definitely wasnt serious, just some nice woofers ya got there! im only 18 i dont have a first born child, and apparently my girlfriend has more ownership of my nuggets than i do anyway, so glws //content.invisioncic.com/y282845/emoticons/rotflol.gif.b453361716769b8110ddefc85ff03cd2.gif
well most t3s dont have problems at least none of the ones ive used ,sold or seen in use they break glass before they had failures but if your refering to t he few threads ive seen on here id say thats pretty bad way to judge a woofer
ive put 3k to each one with no problems
my 15s in my crx took an opti 12k with not a single issue for 2 years had to sell the car cuz the metal was so ripped up
the 18s in my buddys car were on 4 sampsons each before i picked them up and they were only reconed to change impedance.
ive used a lot seen more but the tsns is one hell of a woofer
so were you just dumping my thread or are you curious about buying them ?
Clean up your workbench. Other than that **** moofers and glws. Wish I was focusing on being loud
LOL I NEED ALL THAT STUFF
ca glue
dremel
amp
12vdc power supply
woofertester
o scope x2
nitrile gloves
strippers
crimpers
solder
iron
vice
extra cone and coil pack
a drink cuz im thirsty !
cordles drills
goop
amp clamp
heat shrink
what u see that i dont need?//content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
psychoacoustics
psychoacoustics
Buffalo NY
psychoacoustics
