Synergy Audio WFO 4.150X
  • 2
crosjr
Tampa, FL
Synergy Audio WFO 4.150X 920w RMS 4 Channel
Synergy Audio WFO series are world class amplifiers in Class D monoblock and Class AB multichannel formats. They feature high end design, engineering and manufacturing. We utilize the best quality components to insure the best possible performance and reliability.
•Continuous Power Output @ 14.4V Input
• RMS power @ 4 ohms stereo: 150W x 4CH
•RMS power @ 2 ohms stereo: 230W x 4CH
•RMS power @ 4 ohms bridged: 460W x 2CH
•Signal to Noise Ratio: >90dB
•Low pass frequency crossover: 30Hz-250Hz (ch1/2) 50Hz-5kHz (ch3/4)
•High Pass Frequency Crossover: 25Hz~300Hz
•X10 Multiplier switch for added crossover flexibility
•Subsonic filter: 10Hz-100Hz
•Bass Boost: 0~12dB
•Frequency Response: 10Hz~40kHz (+/- 1dB)
•T.H.D. Continuous @ 4 ohm/1kHz:
•Channel Separation: 75dB
•Input Sensitivity: Variable 200mV~8V (+/- 5%)
•Dimensions (mm): 440(L) x 225(W) x 52(H)
•Operating Voltage: DC 8.5V~16V
•Recommended Fuse Rating: 40A x 3
•Wired remote bass level control
Purchased in January 2017 and mounted so in almost perfect condition. Works great, sounds great, I just came across a deal for an Arc 4100SE that I just couldn't pass up.
$275 Shipped
Fedex in original box
Ill check it out. I was actually on the site last week. Thanks!
241
if you can read a simplistic book you can follow the directions to put together just fine. Its not rocket science. If you have questions about the...
281
16
713
crosjr
crosjr
Tampa, FL
crosjr
