Switch recommendations for adding LEDs
MetalMaxima
AURAL DESTROYER
Ok, so here's the deal. I am going to be adding 10 LEDs to my interior:
6 x Air Vents
2 x Door Handles
2 x Map pockets
...and I would like to tap directly off of my car battery since I can get a nice, clean supply to the LEDs. However, I would like to hook the whole network up to a switch.
Can anyone recommend what switch to use? I would like to use something that I can run 12GA to and from the switch, but all I have seen are crappy 22GA wires on most of the switches I have seen. Thanks!
-D.
um.
go to radio shack. ask for a 12~14VDC toggle switch. but a soldering gun, some solder, and some shrinkwrap.
nuff said.
//edit
each LED will take ~2miliamps on average. so 10 LEDs = 20miliamps. not much current at all. 14awg should be fine.
R U buying pre-packed LED's like hyperLEDS or something, they come ready to accept 12v and a switch. If you're gonna do it all DIY, buy all the stuff REQ said and find a resistance calulator online, figure out how you're gonna wire 'em up, and buy resistors or you'll fry 'em on first power up. The new under $20 ColdHeat soldering guns are easier to use when working with small, heat sensitive things like LEDs. They are also 6v and can be used to test LED's for short periods.
I am doing everything myself and usually test the LEDs with a 9V battery before I install them. The cold heat gun sucks, I'll take my 40W iron any day of the week over it...plus, you can get a real nice solder job with some rosin. I think I am going to be buying a custom switch, just for the hell of it, and attach using 14 GA as req suggested.
i used LED toggles similar to those before. Some didn't have built-in resistors and will COOK with 12v(or 14.4v) running straigt to them. The one I remember wanted 3v to the LED circuit.(b@stards) good luck. post pics when ya get done!
http://www.lsdiodes.com
has a link to resistance calculators, and sells GREAT ultrabright led's yada yada yada.
if i were you, id run 4 to each door (wire them together to use 12~14v) just put them wherever. just for convienece and not using a resistor.
and run 8 to the vents - again, wire them all together, so you have 4 sets of 4 LED's, all without resistors, running to a common posative and ground. the switch should be on the ground.
run a pair of wires to each door, and the vents form the common switch\posative. then from there, hook your array of 4 LED's to each set of +\-'s
its quite simple //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
um.each LED will take ~2miliamps on average. so 10 LEDs = 20miliamps. not much current at all. 14awg should be fine.
2mA is alittle weak, most leds are designed to handle a constant 20mA and peaks up to 50mA.
Be sure to get a resistor on those too or they will fry.
You can shoot me an IM (jeffzimmerman484) if you have any other questions.
MetalMaxima
AURAL DESTROYER
MetalMaxima
The Garden State
djman37
Mike Mccabe
