Swapped to Lawn Mower Batts and I must say
They are not rated with AH capacity. CCA and CA..I have 8 (2 under the hood)
The super starts from o'reilly's they where $21ea brand new they have 410ca so 3280ca total a normal g31 has like 1000ca or so. Also price was like $180tax and all a xs3100 or NSB31 is like 300+ for 1
dude in my area code, that same battery is 52 dollars... talk about inflation up the ass.
How much they where //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif The smaller ones work to, just get as many cca as you can
[/img]
california prices....
Im surprised how well they work. Dom Iraggi talked me into running them, swapped out my big agms for more of the smaller lawn mower batts and my voltage stays just as high, less weight in the rear, and cost alot less. Anybody on a budget.. Or if you are only gonna run 800-1kish(per batt) these are definitely worth looking into
Dom does swear by them. He has soooo many
his werker 100ah batts were on par with any kinetic or high rated agm batts
Crazy thing most people don't realize that there are only a few companies that supply all the batt companies with parts to make them.
I have used kinetik and they ****. An 1800 and 1400 couldnt handle a 3kw amp. I use the enersys/data safe batts. Only batt this better is the odyssey 2150 but its 100 more bux.
Were the speaker ohm-loads the same from factory to the JBLs? That "may" play part. Some head units with 4 to 8 ohm stock speakers really dont...
I just swapped out my factory speakers for JBL speakers in my 2012 Jeep Compass. Initially, the speakers did not work. Then, after shutting my car...
Boomsday
Boomsday
My House
Notloud00
    May 12, 2024
Brendon Jenness
    May 11, 2024
