svr 80-12 vs. d-31 optima yt
Not a fair comparison... if you were going to compare the two brands you would be better off to compare the larger SVR100 to the Optima G31. Here are the specs for each.
Optima
1125 CA
900 CCA
75 Ah (20hr rate)
155 RC
60lbs
SVR100
1100 CA
? CCA
100 Ah (10hr rate)
RC ?
72lbs.
From what I've seen this batt gets alot closer than the SVR 80 does. You have to take their ratings with a grain of salt... some are a little misleading. Of course I'd pick the Optima over either //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
If both batts were tested for the exact same criteria you would see the diff... some battery companies change the terms (ie timebases/temps/etc.) to make their specs look more comparable. The SVR's are great batts... they can compete with any other batt that fits within the same footprint. Like I was saying, the SVR 100 is a much closer comparison than the SVR80...
jeepintn
jeepintn
Greenbrier, TN
scottiej
