Ok well I decided on going with this battery isolator for my ride...My alt is only 105 amps and this is a 100amp isolator so I should have no problems running it correct???
and also would I need to get anything else??? I just got one of dbeez 9A31s to add to my system so besides running more wiring and adding a battery isolator what else would I need to keep the system in tip top shape???
Well no help with that but maybe you guys can answer my question about if its ok to get away with two fuses instead of 3 with having a rear battery....and if so would it be better to mount that fuse on the 2nd run of postive cable from the 2nd battery to the amps or at the end of the 1st wire going from battery 1 to battery 2..
