Sup, bytches?
Still some crybabies (well one for sure) but overall dead haha. A few months ago you should have ran a Taramps with an AB XFL and now you should run a Sundown SFB with sundown, ssa, ab, etc.
I know you ain't talking about me. Now you should run Fi subs and Sundown SIA amps. The SIA is more like the Smart line by Taramps, but made much better and can handle more input. It pretty does rated at 1 or 2 ohms. Everybody loves SSA, Fi, and Sundown subs. Deaf Bonce and Wolfram amps are also very popular.
You should definitely run a skar sub in a small sealed box on a soundstream amplifier.Everyone around here loves skar, and the new soundstream amps put out 165 dbs of power at 8 ohms. Don’t forget to stuff the port with poly fill. That removes the 90 hz standing wave caused by the ridiculous spl skar subs put out. skar subs have a one way linear x-max of 127 mm, so just make sure you mount it at least 36 inches away from the back of the trunk, or the sub will knock out the trunk lid.
[QUOTE="Deaf Bonce and Wolfram amps are also very popular."
[/QUOTE]
Wolfram is catching hell right now for selling hundreds if not thousands of bunk full bridge amps they arrive doa or blow up in almost no time
6- Wolfram 9K's in my friends Tahoe. No problems.
Those are a different animal they are Korean half bridge amps made by zennon similar to about 83 other amps
I didn't even know that Wolfram even made full bridge amps, which isn't surprising. I wonder if people are throwing too many volts at them like the Taramps? Or, possibly wiring them under one ohm? That still wouldn't explain the DOA. Like Coolhand has been saying, the Sundown SIA full bridge amps might be the best ones made so far. My SFB3K is a great amp so far.
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
Buck
vegang
vegang
