no im bullshitin:crazy:
because when it breaks I dont wanna be without a amp for over a month...good, cuz it sure sounds like it. the gp3000s are one of the most cost effective amps out right now considering the amount of power they produce. ewhy dont you buy on.
i am waitin on a amp from there division i guess u would say maxxsonics? is that right. im getting a hifonics XXV Thor and gonna try 16v if i dont fry the truck first i have a lot of reading b4 i set the external voltage reg.good, cuz it sure sounds like it. the gp3000s are one of the most cost effective amps out right now considering the amount of power they produce. why dont you buy one.
//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifbecause when it breaks I dont wanna be without a amp for over a month...
The tests are not comparable as they were not done in the same setups.I agree to!!! both are good amps dont get me wrong, and i had the SAZ-3000Ds cusin the 2007 Atomic 3000.1 there exact same amp, just different name, and that amp was killer, but test vrs. test, the GP3000 takes it!!!Cant deny that!!!//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Haha, I only give advice over there for this same reason. Not ask for it.The tests are not comparable as they were not done in the same setups.
Try these:
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=9952
3237 watts @ 14.4v dropping to 10.75 Volts / 1.33 ohms
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=12103&hl=Sundown
3712 watts on BatCap 8400 / 0.95 ohms
http://www.soundsolutionsaudio.com/forum/index.php?showtopic=7900
5196 watts @ 16.5v dropping to 14.5 v / 0.87 ohms
In any event... unless you test them in the same setup it's difficult to compare apples to apples on these clamp tests.
As for the rest of the thread... I kind of stopped reading... the SAZ-3000D is not the same as the Crunch amp. How anyone can make that connection is beyond me. I suppose that is why I don't read SMD. The board layouts are CLEARLY different and I have internal shots posted for easy access on the site.
