Sundown SAZ-1200D
dross93ranger
Sundown SAX-1200D
This amp works perfect and looks almost new. The only issue is a couple terminal screw holes are stripped out, but still hold the wire well.
The SAX-1200D is the successor to the SAZ-1000D model - it features a newly tooled board taking advantage of newer and more powerful MOSFETs to achieve 20% more power in a casing only a little over 1/2" longer than the SAZ-1000D model that it replaces. Don't let the small size fool you, this amp is a little power-house!
The SAX-1200D is the perfect companion for a pair of SA-10s, 12s, or 15s.
Rated power output ----Rated power output ----RMS power, 2 ohm linkable/dual mono 2160W x 1CH ----RMS power, 1 ohm mono 1200W x 1CH ----RMS power, 2 ohm mono 720W x 1CH ----RMS power, 4 ohm mono 360W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~6dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB)T.H.D @ 4 ohm
$260 shipped OBO
Included
Bump...might have worked out a trade so this is your last chance to make an offer on this amp! Just FYI the power/ground/remote terminals are perfect, one neg and 1 pos are stripped but still hold wire, the other two are perfect.
dross93ranger
dross93ranger
Maysville, KY
blockburner
