Sundown SAE-1200D *CHEAP*
Aldundra
See title
o 1200 x 1 watts @ 1 ohm
o 600 x 1 watts @ 2 ohms
o 300 x 1 watts @ 4 ohms
o 0.153v - 5.6v adjustable input sensitivity
o 15 Hz - 250 Hz Frequency Response
o > 90 dB S/N Ratio
o 4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
o 50 Hz - 250 Hz adjustable 12dB Low-Pass Crossover
o 15 Hz - 50 Hz adjustable 12dB Subsonic Filter
o 0 or 180 degree adjustable phase switch
o 0 - 12 dB adjustable bass boost with 60 Hz center frequency
o Wired Remote Control unit included
o 5x 30 Amp Internal Fuses
o 17" L x 10.6" W x 2.2" H
I'm selling the amp because I'm getting feedback through the sub, which I've narrowed down to the rca inputs on the amp.
The amp is still functional, I'm currently using a ground loop isolator and the amp plays as if there isn't a single problem with it. Since the ground loop isolator "fixes" the feedback issue, I would assume the ground for the rcas on the amp are going bad/went bad.
Normally i would just get the amp repaired, but I've been needing more power and I just bought a more powerful amp, so this has to go.
Cosmetic-wise it doesn't look TOO bad, there are scratches on the amp, I took pictures of the worst parts of them so you can see.
Also, one of the speaker terminal screws snapped on me, so it only has three left, which shouldn't be a problem if you just plan on running one sub off the amp.
Ratings wise I'd give it
Cosmetic - 6-6.5/10
Performance - 8/10 (because you would need to either ground the rca's or use a ground loop isolator to daily the amp)
Because of the problems with the amp, I'm looking for 100 + shipping FIRM. I need to make back some money I just spent on my new amp.
NO TRADES
These are thumbnails, click them to see the full picture
I am going to need internal pics as the one I just got had a **** load of stuff missing internally and was from a very trusted member he swore he never opened and touched it.
I have the amp pending to another member, however if for some reason that falls through I'd be happy to get a gut shot for you
Aldundra
Aldundra
Berlin, NJ
Aldundra
