Sundown NS-1 v. Incriminator 40.1
Both amps are very powerful -- the 40.1 is drastically under-rated in power.
I believe in speaking with users of the 40.1 that is does nearly as much power as an NS-1 despite it's much lower official rating.
ns-1 runs very hot
Inaccurate generalization.
A few users experienced heating under 16v on a small # of amps from the 2nd production; so far I've only seen one case in person of this happening and there was 0 heating on 12v on that unit with an 8-hour test; we are tracking down the cause of the 16v heating on that unit -- this is not the same as "NS-1s run very hot" as a general statement. All other amps functioning normally run quite cool outside of a situation where you would expect any amp to be warm (eg: sitting in 100 degree heat, playing for hours on end, etc)... this includes many other users on 16v.
The 40.1 is a beast. You CAN get more power from it than the NS-1 (probably), but you'd have to run the balls off of it to do so. For a regualar ol' ground pounding daily, the NS-1 is probably a better choice.
ctdv55
ctdv55
Dora, Alabama
TaylorFade
