Sundown nightshade motors
Not easy IMO.. and practically, dont go over 2-2.5K. You will have a better daily driver at this range then trying to stuff it up with a hard suspension for the little tiny bit of output gained.
Its still a 3" coil.
cooling on this motor isnt as great as the new sundown subs but you can put the pole plug to help as well...also i think dave at psi can put spacers on this to also help on cooling
@ evan...hows the amp doing man? any updates
With a pole plug the v.1 can hang with many of the bigger 3" woofers out there -- the v.2 motor has significantly improved coil cooling, though, but that motor is harder to find as I've sold fewer of them so far.
lowriderram_95
VW Surgeon
lowriderram_95
Little Rock, AR
sundownz
