1. Product: Sundown Audio sax50.4
2. Specs:
· 4/3/2 Channel Bridgeable Class-AB Amplifier
· MOSFET PWM Power Supply
· Stable Into 4 Ohms Bridged or 2 Ohms Stereo Load
· 12dB Octave Electronic Crossover Slope
· Variable Subsonic Filter
· Independent 1/2 Channel High Pass Filter Variable with x 10 Range Selectable Switch
· Variable 1/2 Channel Low Pass Filter with HPF/FULL/LPF Selectable Switch
· Independent 3/4 Channel Low Pass Filter Variable with x 10 Range Selectable Switch
· Variable 3/4 Channel High Pass Filter with HPF/FULL/LPF Selectable Switch
· Independent 1/2 and 3/4 Channel Bass Boost Variable Control
· Variable Bass-Boost Frequency Control
· Variable Input Level Control
· Input Sensitivity : 200mV ~ 6V
· Subsonic Filter : 10Hz ~ 500Hz
· Signal Input and Line Out RCA Connectors
· Multi-Way Protection circuitry (Thermal/Over Current/Speaker Short/Speaker DC protection)
· Tested Voltage & THD: 14.4V & Less than 0.05% THD
· Operating Voltage : DC10V~16V Power Input
Rated power output ----RMS power, 4 ohm stereo
50W x 4CH ----RMS power, 2 ohm stereo
80W x 4CH ----RMS power, 4 ohm bridged
160W x 2CH Signal to Noise Ratio >90dB Low pass frequency crossover
50Hz~500Hz (CH1&2)
50Hz~5KHz (CH3&4) High Pass Crossover
50Hz~5KHz (CH1&2)
50Hz~500Hz (CH3&4) Variable Subsonic Filter 10Hz to 500Hz Bass Boost 0~18dB Variable Bass-Boost Frequency Control 35Hz to 120Hz Frequency Response 10Hz ~ 40KHz (+/-1dB) THD@RMS Watts
3. Description/Condition: In great working condition, does have a few scratches and run marks, not perfect but works like a charm.
Amp is dirty in pics looks better cleaned up.
4. Price: :200 shipped to most areas. Slightly neg but send offers to pm's not in here Not looking for any trades atm.
2. Specs:
50Hz~500Hz (CH1&2)
50Hz~5KHz (CH1&2)
