Sundown Amp Not Working
CrownMe
hey, I'm having an issue with my sundown SAE1000D. It simply not turning on. When I test the power terminal with the volt meter its only showing 3.3 whereas if I pull the power wire out of the terminal and test it, its shows anywhere between 12 and 13. I really dont know what it could be, any ideas? ... blown amp? any possible solutions?
no its not, i bought it used off here, it was working fine and then it turned off a while back, it was just waaayyy too cold to look at. So I left it, and every once in a while like every 2-3 weeks it would randomly turn on and then go out a few minutes later
Thanks for the replies... fuses dont look blown, the wire is not loose either, but I will double check the remote wire again, and just replace the fuses just incase, anything else I should check while im at it
check your ground.. maybe it came loose and is vibrating.. causing the circuit to open/close..
^^ my othe amp is grounded at the same place, it doesnt seem to be an issue with the ground.
But would it make sense for it to be reading fine when I pull out the wire, but as soon as it touches terminal even if i touch the volt meter leads directly to the wire it drops down
Maybe a power wire is grounding out inside of your amp?
I had this exact problem,
I absolutely had no problems with my ground then all of a sudden, bam, nothing works, I tried everything except my ground(i thought since it worked before, why would it just stop?). I finally sanded the paint away from my ground and BAM! BINGO!
I read the wires with a meter and they all ready 12 volts until I tried to turn the amp on....then they dropped straight to 3 volts and wouldn't work.
I know u other amp is working fine, however, don't underestimate those tricky bastards..
SAND THE PAINT AWAY FROM GROUND AND TRY AGAIN.
GL,
Bass
CrownMe
CrownMe
Toronto
thefordmccord
slater
    Oct 4, 2025
1aespinoza
    Oct 4, 2025
