sundance
mustangmoe
i was thinking about getting the sundance 1500 or the jl1000/1 the sundance is a lil cheaper and i like the fact that it wont be running on all its power but will the sub sound the same even though im not going with jl which amp do you think i should go with thank for your feed back ill give the specz if you want
yea sundown sorry
w713
Free Air Resonance (Fs): 23.5 Hz
Electrical “Q” (Qes): 0.476
Mechanical “Q” (Qms): 7.517
Total Speaker “Q” (Qts): 0.448
Equivalent Compliance (Vas): 3.68 cu. ft. / 104.3 liters
One-Way, Linear Excursion (Xmax)*: 1.25 in. / 32 mm
Reference Efficiency (no): 0.269%
Efficiency (1W/1m)**: 86.3 dB SPL
Effective Piston Area (Sd): 107.35 sq. in. / 0.0693 sq. m
DC Resistance (Re): 2.41 ohm***
Nominal Impedance (Znom): Dual 1.5 ohm
Thermal Power Handling (Pt): 1000W
Driver Displacement: 0.21 cu. ft. / 5.9 liters
Net Weight: 52 lbs. / 23.6 kg
sundown 1500
1500 x 1 watts @ 1 ohm
800 x 1 watts @ 2 ohms
400 x 1 watts @ 4 ohms
0.2v - 6v adjustable input sensitivity
10 Hz - 350 Hz Frequency Response
>90 dB S/N Ratio
4-Way Protection Circuit (Thermal, Overload, Speaker Short, and Over Current)
Linkable to another SAZ-1500D for up to 3000 watts @ 2 ohms
35 Hz - 300 Hz adjustable 24dB Low-Pass Crossover
10 Hz - 60 Hz adjustable 24dB Subsonic Filter
0 - 180 degree adjustable phase shift
0 - 18 dB adjustable bass boost with 45 Hz center frequency
Wired Remote Control unit included
4x 40 Amp Internal Fuses
17" L x 9" W x 2" H
JL 1000/1
Amplifier Class: D
Number of Channels: 1 - Mono
RMS Power (4 ohms): 1000 watts x 1 channel
RMS Power (2 ohms): 1000 watts x 1 channel
RMS Power (1 ohm): (at 1.5 ohms) 1000 watts x 1 channel
Bridged RMS Power: N/A
Peak Power Output: N/A
Minimum Impedance Unbridged: 1.5 ohms
Minimum Impedance Bridged: N/A
THD at Rated RMS Power: 0.05%
Speaker Level Inputs: No
Amp Preamp Outputs: Yes - 1 pair
Built-in Crossover: High-pass (HP), Low-pass (LP)
High-Pass Crossover Frequency: 40 - 200 Hz
Low-Pass Crossover Frequency: 40 - 200 Hz
Subsonic Filter: N/A
Signal-to-Noise Ratio: 95 dB
Channel Separation: N/A
Bass Boost: 0 - 15 dB
Bass/Gain Remote: Optional (JL Audio RBC-1 required and sold separately)
Fan Cooled: No
Fuse Rating: 100AA x 1
mustangmoe
mustangmoe
staten island n.y
mlstrass
