Suggestions on a mono amp?
adamsdell
I have been out of car audio for a while but I am getting back into it. I know there are alot of good companies out there that have good amps, and many I have never heard of, so here goes. I need some suggestions from you guys on a good 800W/900W RMS mono amp?
Specs I need:
4 ohm - 300/400 RMS Watts
2 ohm - 500/600 RMS Watts
1 ohm - 800/900 RMS Watts
I would like to pay around $250-$300 or less.
Thxs.
I am starting at 4 ohms, but with more subs, those will be running at 2 and then on to the 1 ohms for the final setup. I want the amp flexable for my future plans.
I am still in the planning stages....
excel, what is that 9.1??
gonna be hard to find a mono amp that goes up in minor increments like that...most double in power when going from 4 to 2 then again from 2 to 1ohm. for instance my incriminator is 450 @ 4, 900 @ 2 and 1800+ @ 1
Well thats another good point bones, what about a total of 900W at 1ohm for the final wattage. I figured that the wattage would be close to what I said earlier, but I am still not sure of how the wattage at the different ohms would be.
I'd just get an SAZ1500d and call it a day.
Little more power in the end than you want, but it's QUITE efficient, and the power requirements you listed are NOT realistic at ALL... for a single amplifier.
nG
ngs, that looks like a great amp, a little too much power for me thought, do they make a 1000W version? What do they run if they have one?
Bones
That looks like what I need, your right is it pretty close, what do they usually run?
adamsdell
adamsdell
North Wilkesboro, NC
adamsdell
