Suggestions and recommendations
Not sure what subs to buy I just blew my 2 12 mtx's. I am interested in the kicker comp rt. I am wanting hard punching double bass sound. I had the 2 12inch 2ohm mtx's bridged in the box then bridged to my 2 channel 800w rockford fosgate amp. This is the first time I've blown subs could be from age considering I had this set up for about 5 years now not really sure though. If I were to get the 2 12inch kicker comp rt not sure whether to get them in 1 or 2 ohms and whether to bridge them in the box and then bridge them to the amp. SUGGESTIONS OR RECOMMENDATIONS PLEASE
Also I have a 4 channel 1200w alpine amp running 2 6 1/2 kickers in the front and 2 6/9 kickers in the rear but I am wanting to install 2 more 6 1/2 kicker speakers in the rear. Basically I am wanting to know how to run the wires for the 4 speakers that are going to the rear 2 channels on the amp
what is your amp. can you post a picture of it - or find a pic of your exact amp on the net and post it here ? the final ohm load the amp can run at is determined by what amp it actually is. some can run at only 4 ohm bridged - some 2 some 1 so - its the most important piece of info you need. real specs on your amp
efcivic91
efcivic91
Midlothian, VA
brian84corvette
