Suggest an AMP or AMPS please
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 539
  • 1
U
Unregistered
Guest
Need some help - any input would be appreciated...........
I want a system that sounds consistent and full - not too much bass but enough to feel a good solid vibe.
Ride - Ford Supercrew truck, 4 sull sized doors - minimal space under and behind the rear seat.
Replace the (4) factory 5 x 7's with JL Audio 5 x 7's
Add the JL Audio 10" sub in the stealthbox (center console)
And possibly add the Q Logic kickpanels with JL Audio components 6" midrange and 1" tweeters.
This is where you experts come in........
What kind and power of amps would you suggest, 1 or 2?
Do you think I 'd need the kickpanels?
Any ideal where to mount the amp(s)? Not much room in under the seat.
Thanks
Depending on your budget - I would either keep the front 5X7's and skip the components OR (depending on your listening preference) I would skip the 5x7's in the front and install the components in the kicks. As for amps I can suggest what my favorites are but, there's no knowing if my favorites will match your listening tastes. For bass amp: I would either go JL audio, Rockford, JBL, or US Acoustics class D. I would get an amp that has a slighter higher RMS output than that of the JL 10. For the mids and highs: Alpine, MTX, US Acoustics, Kenwood Excelon. My power recomendation for the mids and highs would be in the 50 watts RMS per channel range.
Get a Wrangler and get naked (you know…the Jeep, not you…none of us want to see that) and you’ll definitely be heard coming. 😉
211
414
494
Guest
natem33
