Subwoofer playing very low/quiet - diagnose?
ls20
I went home at lunch today to pick up my new Image Dynamics ID8 v.3 dual-2ohm today. I didn't have much time, so I hastily wired it up and threw it in the trunk
It plays , but very very quietly - I can BARELY see the cone moving. Its definitely NOT using its 17mm of excursion!!!
Since I am currently at work, I cant go out and start diagnosing it, so curious if anyone can throw some suggestions out here.
HU: Alpine 9857
Amp: JBL GTOII 75.4
Speakers: Boston Pro60 - 125W RMS, 3-ohm
Sub: ID8 v.3 - 150W RMS, dual 2-ohm
Amp makes 100 x 4 @ 4-ohm,
140 x 4 @ 2-ohm
280 x 2 @ 4-ohm (bridged)
Subwoofer recommended ~.4ft sealed box. I put it in ~.4ft sealed box. Connect them in series to present 4-ohm load. (bridged+ to vc1+, vc1- to vc2+, bridged- to vc2-).
HU at 70% volume. EQ off. Subwoofer level set to 0. Bass boost on amp 0dB. Gain setting at 4v = sub barely plays. (comparatively, at same gain settings for speakers, theyre loud).
Flip the filter between Flat and Low pass (120HZ)... nope... still quiet. crank gain up.. louder, but BARELY.
If I give it a bit bass boost, notch up the gains a bit (say, 500mV), add about 10 points to subwoofer level on the head unit, I can get start to get acceptable levels out of the sub
So what the heck is going on? Also tried swapping the sub connector from bridged to single channel mode... not much diff. Do you think I swapped the polarity? messed up when I connected the voice coils? (cant wait to get off work!)
im having the same problem with my sub. sometimes it will come back full swing and have full bass, then cut back down. its almost as if someones in my trunk turning my gains up and down randomly
Set the subwoofer level to +15 on Alpine units otherwise you aren't getting the rated pre-out voltage.
serious?
i read this suggestion while researching, too... thats really BUNK!!!
i presume this is with newer alpines? i had 9815 with a weak kenwood amp and baloney cheap subwoofer and that one performed well without tweeking up the sub control.
jimrhit - when i set the amp on Flat (no filter), i could hear the upper range of music (vocals and all), so i think the phase is alright... but maybe its not indicative and i could very well be wrong
thanks so far!
ahhhh yeaaaaa this thing pounds at sub level 12-15.
it wasnt getting progressively/linearly louder from 0-10, so i thought my install/setup was wrong. i thought default/flat level was 0, and didnt want to "artificially boost" the setup
now ive only got to get this thing to blend in well with the nice solid mids of the Bostons....
thanks !
ls20
ls20
the south
ls20
