Subwoofer makes a bad vibrating sound.
djsyxx
Hi there, I'm new on this forum so hope this is in the right place!
I have a problem with my amp and sub setup in my car. Its not a fancy install but does me fine and its been in my car with no problems in the past. Recently I have had this problem where the subwoofer makes a loud vibrating noise. I'm stumped because I can't find the cause of this problem. The setup I'm running is a JBL GTO 2000 amp, 12" Pioneer sub, 8 gauge wiring kit, and Pioneer MP3 headunit. I had someone who knows a bit about car audio and reckoned that one of my channels on my amp has blown although there maybe a possibility the RCA cable (phono cable) is damaged and advised getting a new amp.
I've purchased a brand new JBL 2060 amplifier and I'm still getting the same problem. I have also tried 2 different phono cables to see if it makes a difference and no luck at all. The volume of the amp is not high at all, only around 1/3 of the way up and it seems to do it from a very low volume level when I start to turn the volume up on the headunit.
I was hoping someone might come up with an answer?
Thank you.
Rich.
if the channel on the amp was blown then there would be no signal, so i dont' think the amp was the case.
if the sub was making the noise then i would have tried replacing the sub first.
Someone looked at ur system and didnt tell you to junk the Pioneer?.....Hopefully its actually one of there good subs //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
But yeah I would try a replacing the sub
its probably something physically wrong with the sub itself. Do you some buddy that was any sort of sub you can borrow for like 5 minutes just to test it in your car if it makes the same sound. If it doesnt.. then you know its the sub.
A long shot, but a possibility, it could be something rattling besides the sub. Look for loose panels, etc. I guess you could try it outside the vehicle. I thought I blew a sub, but come to find out the headliner was vibrating.//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
are the subwoofers supposed to make a loud vibrating sound?
nothing is broken, its just working really good
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif :laugh: does it sound like this??
djsyxx
djsyxx
london
TreyE
