rise is caused by various factors. among the easiest to explain is heat. hot wire is more resistive.
the less obvious reason is that the speaker is a "transducer". it converts electrical energy into mechanical energy. but it also converts mechanical energy into electrical energy. this is mostly given by the T/S specs and is fairly well classified. this "reflected load" of the moving cone/air combo can make the speaker seem like a high impedance.
if you look at it, its neat because (at a resonance) the SPL plot shows a decent SPL, but with low power. that is high efficiency. but all the SPL is delivered by the cone, and that means high excursion. a ported box has a similar high efficiency, but the sound is delivered by the port (less cone excursion) AND the impedance is lower allowing for more power.
