subwoofer HELP
is that because thay move more at a lower note and move less at a high note.
I think it depends on if the sub is playing below tuning in a ported box. Say the box is tuned for 35hz, and you play a 20hz tone all day full tilt, the sub has no control over it's cone, and things become crazy. The sub can go into over-excursion causing the coil to come out of the gap, or the sub can literally just tear it's self apart. High notes won't have this problem.... I guess unless you tune your box to 50hz and play 30hz note songs all day.
ok thanks.
If you don't put a reasonable lpf, your sub will
1) sound like shit
2) make distress signal like : brrrrrrrrrrrrrpp.... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
On the low end, I guess it's more a power and tuning question, just don't let it bottoming out
If you don't put a reasonable lpf, you're sub will1) sound like shit
thanks man.
Burp09
Burp09
meridian, ms
Burp09
