Subwoofer Glue
juukno
<Mr. JuU KnO>
Hey guys, I just recently had my MA Audio 15" EHO152 installed and lready has a problem. It is not blown but the glue holding the cone to the base (not the foam) started coming apart and is now completely detached. What type of glue is recommended to hold this together due to it getting around 2000w rms. Thanks for the help..
i just checked out something called maxi-cure super glue.. am i gunna have to remove the old glue before re-gluing or can i get away with adding a thin layer all the way around?
I would just add a thin layer all the way around, as long as the surface is semi rough it should adhere.
Gorilla glue expands and doesnt work well at all.... use the right shit, CA glue its easy to come by
I would go with medium or thick, the thin stuff just doesnt work.
There is also some prep stuff for use on aluminum to promote adhesion, but i would try it without that first, it probably will hold just fine
juukno
<Mr. JuU KnO>
juukno
Palm Bay, FL
pawn man
