Subtilis 12
Looks pretty decent. Definitely doesn't seem like a very loud woofer with the low fs and pretty low efficiency, but would probably make a good daily sub that can pick up the low notes well in the right box.
Spec wise kinda reminds me of TC woofers but with a slightly higher qts value.
How would it perform in a box tuned low to 28 hz?
WinISD says(fwiw): 2cubes @ 28hz
Very solid woofer, and it gets very loud, not sure about what you mean RyanM923. Sounds great in a ported enclosure on rated power
83.3db just isn't very efficient, but that's what you get when you have a higher mms to achieve a lower fs...it's all a trade-off. Not saying that it's bad; it certainly has it's advantages depending on the kind of response you're wanting.
Every model I've done so far makes these woofers look like absolute studs //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Quite easy to make flat. Also easy to get a sizable peak at tuning for those who prefer that sort of thing.
pimpolligist16
HOLA HOLA HOLA HOLA
pimpolligist16
IL
CL1CKCLACK
