Subs
Daniel (or anyone else), have you tried Infinity Perfect's and compared them with the RF's mentioned above ? If so, which do you think are the best ? And why ?
I've heard that Infinity's are only SQ, and performs poorly when it comes to SPL. True ?
I have always found the Perfect's appealing but have never had the chance to listen to them in a good setup.
And to draw this even further, how do you guys think the Perfect's would hold up against the MTX 6000 & 8000 series ?
well 2 12's will hit harder than 1 15 due to the fact that there is greater displacment....where as the 15 may hit some of the lower notes the 12's will have a higher db level....good luck
two 12" type r's in the same size box as one 15" type r and lets say 500w rms which one would win.I think it would be very close.I know for a fact 2 12" type r's can hit 145 db's in an alpine box and i herd that some guy with a pre fab box hit 145 db's and was using a RFbd1000 to push them.Taylor says his 15" type r hits 143 in a 1.5 cu. ft box with a 1000w rms amp pushing it(correct me if i'm wrong).This is all i know about type r subs does anyone else know anything?//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
MR_LOWRIDER
junior spl'r
MR_LOWRIDER
CANADA
MR_LOWRIDER
