Subs stoped working
checked all parts where wires connect like behind HU, speaker wire in the sub box, etc.?
dont know if this could be anything but make sure none of the wires are grounding out..
checked all parts where wires connect like behind HU, speaker wire in the sub box, etc.?dont know if this could be anything but make sure none of the wires are grounding out..
I realized they are parallel subs series voice coils, so I don't think one wire being off should cause both subs to go out, but I will still give them a check just for the off chance that they both happened to fall off.
Sorry for lack of info they are DVC Kicker Squares and a mono Alpine amp.
I'm thinking it might be the amp since I did check the HU, if it is the amp, will I be able to tell by putting in a Ohm Meter to the Speaker Cable output + and -?
I pluged my sub RCA into the speaker output, no sound so its not the HU, checked the fuses they are all fine. Now if I Ohm Meter the amp and get no signal it IS the amp correct?
TheJuggla1
TheJuggla1
Surrey BC
TheJuggla1
