Justintoxicated
Willbe getting 2 TC1000's and I need a 1 ohm load
Would it be ok to wire them in || at the box instead of at the amp?
I have KnuKonceptz thickest speaker wire (Don't remember what gauge). I'm about out of space in the truck under the door sills so it may be a cleaner install to wire them at the box. (Less wire to hide under the sills as all the amps power wire will be run there as well (I know it's best to not have them next to each other, but there's not really another option).
The problem is the wire does not like to fit in the push terminals as it is, however theres actualy 2 sets on each side (box is a prototype and came this way). So I can connect the extra set internally in ||.
Since I'm only talking about pushing about 600 watts RMS will this be ok?..........
or should I go ahead and try to run both wires all the way to the amp even if it means having wires laying on top of the carpet rather than hidden?
