amp is already fan cooled internallyoverheating? could u hook up an aux. fan?
I never said you were, I was just throwing it out there. Accidents occur. Throw external fans on it too!i know for a fact they are not wired to 1 ohm. lol. i am no noob , i think it's the coils heating up. the amp does way more than 800 , it will pop four 20 amp fuses like a a rubberband , gotta run 30's in it. i'm willing to bet it does between 1000-1100 watts , and my subs are only rated for 300 each , thats almost double the rated power they are seeing. the coils definetly get warm. so its prolly the impeadance dropping like winky said. i can do it in half the time if i play lil jon bitch slowed down. lol
---------- Post added at 01:54 AM ---------- Previous post was at 01:54 AM ----------
yeah , my dmm reads 4 ohms at the amps terminals. maybe i should put it on there after i get them hot and see what it reads?????I never said you were, I was just throwing it out there. Accidents occur. Throw external fans on it too!
how do i measure impeadance with them moving?? i have never seen that done before , is there a procedure for correctly measuring like that?Run a tone sweep and take imp readings for 30-50 hz. The system doesn't have to be full blast for this. If the readings drop below 3.5 ohms for long the amp will prolly protect but during music it might only see that reading for a sec. Lil john bítch is mostly a continuous bass line and slowed it holding certain frequencies longer than normal.
