subs and wiring question
bvr_j_0969
ok ive decided 2 10" re se's need to much air space for me to be able to port them so ive decided to go with the RE 8's
my questions are
1. could you wire 6 re 8's to 1 ohm?
if so
which would be better/ louder if you can determine that
4 re 8's ported
6 re 8's sealed?
yes the amp is 1 ohm stable
but the subs are actually 3.2 ohm dvc but called 4 ohm?
what if when wired down it come out lower then 1 ohm?
can anyone do the math on that i dont know how
Shouldnt they do that to combat imped. and box rise...soo it actually might be a lil higher than 1.3ohm u should be fine.
i was hoping to get it at 1 ohm not actually higher because at 1 ohm i will be like 12 watts rms under powered on each voice coil, with it wired at like 1.3 ohms i think i might be getting around maybe 7-800 rms?
bvr_j_0969
bvr_j_0969
kentucky
bvr_j_0969
