Sold subs and amps. for sale or trade.
PowerNaudio
the power of audio
make offers! shipping will be given if youre going to buy the item.
my zip is 76543 killeen, TX.
no low balling. pictures of actual item will be provided via email. to very intereted individual.
as far as trades go im interested in high power subs and amps and a high current alternator for a honda prelude 1992 with the J22A1 engine pm for info. and or offers or aim me or hit me up on yahoo im powernaudio on all.
$150
only one, "brand new in box", i can go to best buy and make it a 12" if you pay the diffrence.
Alpine SWR-1042D - Alpine 10" Type R
4 year warranty from best buy about 2 years left.
Features:
* frequency response: 26-500 Hz
* power handling: 50-500 watts RMS
* peak power: 1,500 watts
* 10" component subwoofer
* Kevlar-reinforced pulp cone
* cast aluminum frame with perimeter venting
* dual 4-ohm voice coils
* sensitivity: 85 dB
SOLD
two sub, sold separate or as a pair, "used in good working conditions".
Directed Audio Studio 3128- 12" dual 4ohms
Features
■ Up to 500 watts RMS, 750 watts peak power handling
■ 14mm Xmax (one-way linear excursion)
■ Optimized for small sealed or vented enclosures
■ Proprietary die-cast aluminum baskets for rock solid assembly
■ Wide nitrile butyl rubber surrounds allow more excursion at low frequency
■ Mineral-filled low resonance 1mm thick polypropylene cones
■ Four layer, 2.5" diameter voice coils on black anodized aluminum formers
■ Long throw motor assembly with bumped back plate and vented pole piece
■ 100 oz. magnet stack with 150mm front plates
■ Custom rubber magnet cover protects motor assembly
■ 5-way gold binding posts accept heavy gauge cabling
■ Freq Response: 35-2500HZ
■ Efficiency: 88db
http://www.mmxpress.com/dei/images/StudioSub.jpg
$35 each
two subs sold separate or as pair
jensen,8" sub, dual 4ohms. in a Bazooka style enclosure port on back.
power handling unknown.
AMPS
$140
Magnata Classic 360 "used in good working conditions".
4 channels
4 x 90wrms @ 4ohms
2 x 90wrms + 1 x 180wrms @ 4ohms
2 x 180wrms @ 4ohms
Freq. Response: 5Hz ~ 50kHz
Fuse: 2 x 25A
Dimensions: 15.8" x 10" x 2.1" (40.2cm x 25.4cm x 5.4cm)
Weight: 10 lbs. (4.5 kg.)
http://ampguts.realmofexcursion.com/Magnat_Classic_360/
$25
Virtual Reality Sound Labs VR3 (AKA Roadmaster USA) "used in good working conditions"
VRA 2.0
200 x 2
fuse: 1 x 20a
http://i15.ebayimg.com/01/i/07/28/b5/48_1.JPG
sold
Kicker Impulse 2252XI "used in good working conditions"
features
2 x 225W @ 4 ohms (12V)
2 x 300W @ 4 ohms (14.4V)
2 x 350W @ 2 ohms (12V)
2 x 425W @ 2 ohms (14.4V)
1 x 700W @ 4 ohms bridged (12V)
1 x 850W @ 4 ohms bridged (14.4V)
Fuse: 2 x 40A
http://ampguts.realmofexcursion.com/Kicker_2252xi/
$150
Rockford fosgate Punch 700S "used in good working conditions"
2 x 175 @ 4ohms
2 x 350 @ 2ohms
1 x 700 @ 4ohms
Fuse: External 60amp
"bass knob included"
http://www.audioonlineoutlet.com/rockamp1.html
http://www.rockfordfosgate.com/scripts/rightnow.cfg/php.exe/enduser/std_adp.php?p_sid=dY1Xb7ki&p_lva=&p_faqid=278&p_created=1083251784&p_sp=cF9zcmNoPTEmcF9ncmlkc29ydD0mcF9yb3dfY250PTEmcF9zZWFyY2hfdGV4dD03MDBTJnBfc2VhcmNoX3R5cGU9MyZwX3Byb2RfbHZsMT05JnBfcHJvZF9sdmwyPTEzJnBfY2F0X2x2bDE9fmFueX4mcF9jYXRfbHZsMj1_YW55fiZwX3NvcnRfYnk9ZGZsdCZwX3BhZ2U9MQ**&p_li=
SOLD
JL audio 500/1 "used in good working conditions"
1 x 500W @ 1.5 to 4 ohms (11v - 14.5v)
THD:
S/N Ratio: >95dB below rated power
Freq. Response: 5Hz - 500Hz (+0, -1dB)
Damping Factor (at 50Hz): >500 @ 4 ohm / >250 @ 2 ohm
Fuse: External 50A
Dimensions: 13.4" x 9.25" x 2.36" (34cm x 23.5cm x 6cm)
http://ampguts.realmofexcursion.com/JL_500_1/
PowerNaudio
the power of audio
PowerNaudio
killeen, TX
MADaudioTN
