sub wiring question
snoopysnooper
german engineering= fail
i just got 3 10" jl 10w3v2's from my buddy
only prob is, 2 are dual 2's
one is a dual 4
the dual 2's are wired together at 2 ohms
and the one is wired at 2 ohms
so my question is, if i put the 2 dual 2's at 2 ohms on the dual 4 at 2 ohms that would infact make a 1 ohm load correct
and is that a good idea to do?
try not to flame this question too much, i got a mad good deal, too good to pass up, so im just wondering
i think the two 2 ohm subs will see less power each then the single dual 4 ohm,,so it might not work well,are you gonna put this on the st 1000d?
well whjat im askign is
i can wire both the dual 2's to 2 ohms then wire the dual 4 to 2 ohms
but ik what yer saying, idk, i guess well see
regardless, think itll sound okay?
if it was me i wouldnt do it,id try and find two more of the dual 2ohms and run it at 1 if its the st your useing.,, could use 3 of the dual 2's on it but you wouldnt be getting full power.
snoopysnooper
snoopysnooper
Saratoga Springs, NY
pr-festiva
