Sub wiring help needed.
bizzy07
IA
My friend just bought an Orion 2500d and three fi ssd dual 2ohm 10's. When he bought all of this he did not think about the wiring options. I have been trying to help him and this is an idea, but I do not know if it will work. I am not sure if having the different loads will cause the sub with the lower impedance to get more power than the others. I also dont know if this is exactly how to wire the subs to this ohm load but I calculated it all and it should be right. Here is a pic: (sorry for the crappy pic... made on paint)
Any help would be appreciated.
i dont think you have it drawn right but go here, http://www.the12volt.com and look on the left side and scroll down you will see a link that says woofer wiring click it and then select 3 speakers and dual 2 ohm and it will show you the correct way
I tried this but I was pondering on how to get these subs to present a load between 1 and 2 ohms to the amp.
bizzy07
bizzy07
IA
bizzy07
