Sub wiring and amp frequency
BenD188
What would be the best way to wire my subs for the best sound and good bass? Also what should my amp be set at? Frequency.. Etc.
My setup:
Two 12" mtx 4500 subs in closed box.
12" 4-ohm subwoofer
carbon-filled poly cone with foam surround
frequency response: 29-150 Hz
power range: 50-225 watts RMS (450 watts peak power)
sensitivity: 89.8 dB
top-mount depth: 5-5/16"
Kenwood Kac-8105D 1000-Watt Class D Mono
From Class D Mono Car Audio Amplifier
1000W Max Power
300 X 1 @ 4_
500 X 1 @ 2_
Thermal Management System
he has two 4 ohm SVC subs.
you wire them in parallel for a 2 ohm load.
start with LPF around 80Hz
set gain based on the pre-out voltage of your head unit. if 2V then set gain at 2V. if you don't have an aftermarket head unit, the process becomes more complicated but still doable.
BenD188
BenD188
OFallon mo
keep_hope_alive
