Sub not hittin at all, both amp and sub fairly new
fire919
can someone help, am trying to run at 4ohms. below is how its wired. bass sounds very shallow.
ok so will try that mylow10.....and i basically just turn the knobs for LPF, subsonic, phase, gain until i got deepest bass response. which at the moment ***** leading me to believe something else is wrong
thats not how you set the gains ,you might wanna read the sticky here for setting gains properly .also try wiring the sub to 2 ohms for that amp
ok so i tried suggestions, and still sounds like crap. don't knw if this means any thing but i use another amp for my 4 interior speakers. and my primary power wire (4gauge) has 120anl fuse inline connected to a distribution block which has 2 80 fuses, one for each amp. (i ain't had no more wire //content.invisioncic.com/y282845/emoticons/suicide.gif.a649d21efc0d1fd4890a6428166586c1.gif)
---------- Post added at 04:37 PM ---------- Previous post was at 04:36 PM ----------
that sub is a dual 2ohms how do i do that?
ok the spec sheet says the amp will run at 1 ohm ,then run it at 1 ohm ,also what box are you using ?
fire919
fire919
the bronx,NY
NIHL8ION
just call me KeV
    Oct 9, 2025
just call me KeV
    Oct 9, 2025
