Sub in the corner of the trunk?
  • 3
GregFarz78
16
PA
Anyone running with this setup? I'm curious b/c a friend of mine knows a local guy that will build a custom fiberglass enclosure that will fit perfect in the corner of the trunk and blend in with the carpeting. I'm just wondering about the sound asthetics of this setup. Would it sound bad with just a single 12 in one corner of the trunk //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
My friend has a setup just like that, sounds good:cool:
just make sure it has the right airspace that it needs and you should be fine.
Ok my next question is how do they make boxes like that? Do they build a box to spec out of MDF then fiberglass around it to make it look nice in the corner of the trunk?
every car is different in the way the sub will sound given its location and direction. making a small sealed box and placing it in different locations in the trunk is the best way i know to determine how it will sound once installed.
how do they build it?? in most applications, the only mdf will be used for the ring that the sub attaches to. Plastic is layed over the area to be glassed and then its time to glass it all in. building layer on layer of resin and fiberglass mesh until a desired thickness is reached and the desired shape is there. takes a bit of practice and is a bit more complex then my description but hopefully you get the drift.
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
168
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
270
I've been a fan of the JL shallow mounts, and have actually heard a decent box with some Pioneers but the Focal are pretty darn good. The JL TW's...
7
318
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
356
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
301
GregFarz78
GregFarz78
PA
pburt
saints747
    May 7, 2024
saints747
    May 7, 2024
Latest topics
