Stupid question - multiple ports
samson
Running some calculations for a box that says the minimum diameter for the port should be 4". When I plug that into the calculation, the port should be around 16" long. The problem is, the box only has 7" to play with (funky under the rear seat thing)
Assuming pi x 4" diameter x 1 port = pi x 1" diameter x 4 ports, shouldn't they both pass the same volume of air? With four 1" ports, I can use 4.15" length to tune it.
Any experiences? Will this work and avoid port noise or do you think it'll sound like ars????? Better off just using one 2.5" port??? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
one 4" port area
area = pi x r^2 = 3.14 x (4/2)^2 = 12.566 in^2
four 1" port area
area = 4 x pi x r^2 = 4 x 3.14 x (1/2)^2 = 3.141 in^2
beaten //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
And I never thought geometry would come in handy. You're right. Looked it up.
Area = pi x radius squared. So much for my memory. It would take 16????? That right?
So much for that idea.
samson
samson
Midland, TX
iamamp3pimp
