STUMPED on round port length for my WALL
Just went out and bought 2 sheets of MDF to get started on this tomorrow. Want to wall off the back of my truck, but the design wont work if the port ends up being to long. My design is only 17" deep and uses 2 8" sonotubes
Box dimensions. 37.5 X 32 X 17 (17 depth)
So this box is 10.447 cubes. BEFORE sub, port, bracing.
Im having trouble figuring out the ACTUAL port length Im going to have to cut these dual sonotubes to get a 38hz tune, I get 12.09" with box volume alone, but dont know how to subtract port displacement etc and how that affects my length.
I basically just want a 10.447cube box tuned to 38hz with 8" sonotubes
7" to long what??? When I did the calcs they were only 12"
Maybe you didnt read that i have TWO 8" ports.....
ANd yes you were right on the dimensions, but Im defientely doing sonotubes.
i got a volume of 9.7 after port displacement and the ports being 13.49" long for 38Hz but even at 12 inches that dont leave you a port diameter away from your back wall im guessing thats why a L port was recomended and i agree
is my calculator broke? im getting 9.8489 cf just with those measurements up there... not including the wall thickness so 36 x 30.5 x 15.5 internal dimesions get you 9.8489cf
im getting right at 14.95" long each for 8" sonotubes bringing your net volume down to 9cf. still not including sub displacement.. should be a good box for 2 15"s though. the ports are going to be too close to the back wall, there will only be about 1.25" from the end of the port and the back wall.
why dont you try a slot port?
A slot port could be 20" x 6", 15 1/4" long. Giving you 8.2cf after port AND sub displacement. and thats right at 15sq inches of port per cf. 38hz tuning
he diddnt say if those were inner or outer dimentions or how thick he was going to make the walls,,things that need to be known:)
WOT
Banned
WOT
Toronto,CANADA
pr-festiva
