Stuck between two amps. Any help?
MellowHype
So i have an alpine type R 12", rated at 600wRms. It is the dual 4 ohm version so i need an amp around 600wRms at 2 ohms. I am stuck between two, one is the Alpine MRX-M50, rated at 500watt at 2ohms. And the other is a Kicker EX1000.1 rated at 700watt rms. They are both the same price. I want to know if its gonna be safe to get the Kicker and power it a 700wRms. People claim they power their R's over 700wRms all the time, but could be bs. The sub is going in a ported enclosure 2cubic ft at 32hz. Even know the kicker is more powerful, is it still a good amp?
Alpine MRX-M50
Kicker EX1000.1
Plenty of people give Type R's over rated power. I vote kicker of those 2
Yeah im thinking the same because i dont want to be underpowering the sub. If i go with the kicker should i set the gains with a DMM as if its a 600watt speaker, or 700watt? eg 600x2 = 1200, square root of 1200 = 34.64v or 700w = 37.41v. Is that the right way to make sure the amps putting out a specific wattage?
Also..
Alpine -
Crossover Frequency (LPF): 50 - 400Hz (-12dB/oct.)
EQ (Equalizer): Bass EQ (fc=50Hz) 0 to +12dB
Subsonic: 5 - 30Hz (-24dB/oct.)
Frequency Response (+0, -3dB: 1W into 4 ohms): 5 - 400Hz
Frequency Response (+0, -1dB: 1W into 4 ohms): 10 - 300Hz
THD+N (10W into 4 ohms):0.004%
THD+N (Rated Power into 4 ohms):0.04%
Damping Factor: >1000
Signal to Noise (Rated Power into 4 ohms): 114dB
Kicker -
Frequency Response: 20Hz-250Hz
Signal to Noise: >95dB
Input Sensitivity: 200mV-6V
Variable Low Pass: 35-250Hz, 24dB/octave
Variable Bass Boost: 0-15dB @ 45Hz
Do these points matter alot? like the signal to noise?
Thanks for your help dude
That Alpine has nice specs with the 114db rating, but that Kicker has more juice, and Most Kicker gear is under rated/or always has been.Id go Kicker out of the two amps you chose
Defiantly. LOL 😂 It has never happened to me👀:poop:
694
No. Unfortunately, this seems to be a common issue with the Jensen Car1000. I have one that is less than a year old that gets stuck some days. I...
When you random through your music library, you know you got your gear dialed in nicely.
18
Pull it and test it at the battery post. Simple Power up test to verify if it powers up fine out of protect mode. if it does then Id be checking...
MellowHype
MellowHype
Uk, London
LosIsATool
    Jun 1, 2024
    May 31, 2024
