Strongest 3000 watt Amp ?
B2 zero.7c
---------- Post added at 12:51 AM ---------- Previous post was at 12:50 AM ----------
Frequency Response: 15 Hz ~ 250 Hz
Signal to Noise Ratio: >100 dB
Input Sensitivity: 6 V~ 0.2 V
Crossover: 24 dB / Oct
Low Pass Filter: 35 Hz ~ 250 Hz
Subsonic Filter: 10 Hz ~ 50 Hz
Bass Boost: 0 ~ 9 dB
Bass Boost Frequency: 45 Hz
Phase: 0 ~ 180°
Damping Factor: >300
Power Terminal gauge: 0 GA x 3
Fuse Rating: 450 A
Operational voltage: 9 V ~ 15.5 V +
Dimensions: 25.6" x 11.8" x 2.52"
9V 12V 14.4V 16 V
Power @ 4 Ω: 1 x 600 w 1 x 600 w 1 x 750 w 1 x 900 w
Power @ 2 Ω: 1 x 1200 w 1 x 1200 w 1 x 1500 w 1 x 1800 w
Power @ 1 Ω: 1 x 2400 w 1 x 2400 w 1 x 3000 w 1 x 3600 w
Power @ 0.5 Ω**: 1 x 6000 w 1 x 7200 w
Pretty sure the AQ 3500v1 is rated 750@4 by USACI....or RD D5's, or B2 mentioned above. If getting "cheater" amps expect to pay a premium....
Also USACI is going to start clamping some of the low power classes, so you might want to look into that first.
B2 zero.7c
Phase: 0 ~ 180°
Fuse Rating: 450 A
9V 12V 14.4V 16 V
These are what Id like to get...But I may have to run my D5's instead
Louisiana_CRX
dem shoes......
Louisiana_CRX
Piney Hills of Louisiana
Louisiana_CRX
