strapping an amp
i just recently purchased 2 powerbass extreme dual 1 ohm 15s and two planet audio p2250 amps i have never strapped to amps before but i would like to strap the two amps to 1 ohm could some please explain EVERY step of strapping the two amps together because i dont have a clue about any of it thanks
You cant get a 1 ohm load at of those amps. You can get a 2 ohm from each, or .5
Are those amps strappable? All amps are, but if they arent made for it already, like a master/slave switch etc.... its harder. Check the manual or the website.
to figure out what power the amps strapped will have, the amps see bascially half of the ohm load thats there. So for 2 dual 1 ohm subs, you can get them to 1 ohm at the subs, or .5 to each amp, .25 at the subs, or .125 at the amps, or 4 at the subs, and 2 at the amps
I dont know what the amps are capable of, but the best would be to get 4 ohms at the subs, then that would get 2 ohms at the amps.
If you are competing, you could try having them wired to 1 ohm, then that would bt .5 at the amps.
patalpine
Banned
patalpine
LAKE ARTHUR LA
patalpine
