strapping amp
csu87
so im strapping my amps and want to make sure i got the sub wiring right.
its a dvc1ohm sub and im wanting a 2ohm final load at the amps.
series paralell and then each amp will see 1 ohm.
ps..
+ of 1 coil wired with - of 2nd coil
and then wire of the remaining - of 1 coil and + of 2nd coil to amps...
basically run a wire from the negative on the master to the neg. on the slave then from the slave run a wire from the + to the - on the sub and + from master to + on the sub i would run 2 wires from the master to the slaves -'s to strap them if i were you..dont forget to run the jumper rcas
When I strap my amps I put the positive speaker wire to the positive on the master amp, Negative speaker wire on the positive of the slave amp, Jumper the negative of the amps with 8 gauge. Then I use the phone cable that came with them to connect each in the back. Only the master gets a set of rca's.
yeah i ran the jumper rcas and everything. i just didnt know about running the + on sub to - on amp. just didnt seem right to me. ill go try it out and see if that works. if not, ill just run 1 coil to one amp and another coil to the other
csu87
csu87
C Springs, CO
csu87
